Finding numbers on Tractor
I took the numbers from a 1963 posted on this sight to use as a reference. I found the serial number and engine number with no trouble. The rest clutch, axles and so on did not seem to in the same ball park. Any help on where to look?
Re: Finding numbers on Tractor
under seat /hyd/lift cover
right side on gearbox
also there will be a number on trans box near the difflock pedal
and on both back axels looking from back of tractor
all numbers are 3numbers.letters not the[ TS7000 ]numbers these are on all
dextas
dextas
