Hi hope you can help I'm after the location of where the temp sender would be located on a super Dexta as mine been disconnected and can't find it to re wire , also where the tacho cable threads into on the engine the cables there but not on or in anything . Pictures would be great . Thanks
Hello Simon,
Not sure about a Super Dexta but on a standard Dexta the temp sender and tacho drive fit into thermostat housing and injector pump accordingly. See picture.
Hope this helps and that someone will correct me if I'm wrong.
Alan
