oil leak from clutch peddle
spike
Post by spike »
Me again
forgot to ask i have oil coming from the clutch peddle (not a lot) well from were it fits on to the rear drive body just at the back of the left foot plate, i think it is axle oil (bit milky) and is dropping on to the foot plate.
is there a seal that i can change were the clutch shaft comes out that the peddle fits on to, i think the pto leaver is attached there as well but that comes forwards well i think it dose a rod comes of the same point under the foot plate.
any way waffling on back to oil leak any info would be great.
vintage tractor show at astwood bank Nr redditch on the 13/14th june i am going to see the fordson guys if any of you show there it would be good to put a face to the name
spike
Re: oil leak from clutch peddle
Post by spike »
found a post on fixing the leak
by Tubal Cain » Mon Oct 17, 2011 9:17 am
An O ring is used to seal the PTO lever.
