I Looked closely at my Super Dexta Tacho last night. The scale markings refer to gears, and I assume give the ground speed for each gear, the only problem is it only shows 4 gears when there are 6. Is it the wrong tacho?
Ian
Tachometer
Re: Tachometer
Nope, most of the Dexta range is like that.
