Injector lines Super Dexta
Bchaney
Post by Bchaney »
Can anyone tell me where I can get the three fuel injector lines that go from the injector pump to the injectors on a 63 Super Dexta. A parts number would be great also. Thanks Brent
Re: Injector lines Super Dexta
If you take your old pipes into a diesel shop they will make you some new ones to pattern.
Bchaney
Post by Bchaney »
Ok thanks. I'm missing two but I'm sure they can get close.
anthonygos
Post by anthonygos »
I would have thought it would be difficult for someone to make them if they don't have copy's to go by, take a look over the internet. (edited from my first post)
Post by Bensdexta »
I'd try for some original ones first. Try Malcolm Hipperson or Bertie Dunlop.
Also they do come up on ebay from time to time.
Send me an e-mail ASAP. Injector pipes available at around $16.00 each plus postage.
Do not think Major ones will fit they will be too long. Strangely the length of pipe may have an affect on how the engine runs. I have deleted your post as it contains your e-mail but noted it.
Bchaney
Post by Bchaney »
Thanks, where did you see the injector pipes? I always jump to quick on parts.
