Super Dexta fuel filter bolt
Does anyone know the size and thread count of the bolt that holds the diesel filter together? I lost mine and none of the ones in the stores around here will work. Thanks Brent
Re: Super Dexta fuel filter bolt
Might be the same thread as the oil filter. Worth a try - that would tell you the thread.
Try 5/16 unf Cheers Les.
After days of looking around the shop and at stores for a replacement. I gave up and said a little prayer and found it two second later at the bottom of my spare bolt and nut bucket. Must have thrown it in there on accident.
