First the nose cone, I decided to get all the tin work shot blasted and primered before repairing the holes, although some primer was inevitably burnt off when welding, it worked out quite well.
Splits and a very fragile lower edge.
Cut off and a new piece cutout with tin snips then welded in.
Shaping the last bit.
The side cheeks were peppered with holes, from pictures I've seen it looks like a common problem on Super Dextas
I filled these with plastic padding, it would have been too much work for me to try to reproduce the metal work.
Next the wings, the left was much worse than the RH side. there was nothing else to do but cut the bad metal out.
Then make a patch for the panel.
Then build up the box section, I couldn't fold the whole thing so I did each side separately with two Z sections, they
overlapped on the inside face giving a double thickness for part of it.
The Left wing only needed small pieces, and some filler on the face side.
I'll add more pictures in due course.
Ian
