Oil blow out on super dexta
Hi, my super dexta is blowing oil out of the oil dipstick and the vent coming out of the vavle cover. It wasn't doing this a month ago before I stripped it down to clean and paint. Any suggestion. Thanks Brent
Re: Oil blow out on super dexta
One more thing. I also had a issue with getting some diesel in my oil. I do know if that would cause this. Thanks
Sounds like head gasket to me, others may expand on this.
Ian
Ian
I have recently put on a new head gasket. I have a leak at one of the chamber cap, do you think that would cause the blow by? I think the diesel problem was due to turning the engine over some much trying to crank it. Thanks
Maybe it is compression blowing past the rings?
Ian
Ian
Yeah that's what I was afraid of. Thanks
Hi I had oil blow out exhaust oil slabbed and after A good days work it cleared up I also changed
The oil from multi grade to straight 30 this might help
