cleaning gunk from rear axle
spike
Post by spike »
have you any tips on best way to clean the creamy gunk from rear axle before i put some new oil in, same for gear box.
many thanks in advance
spike
ianpdexta
Re: cleaning gunk from rear axle
Post by ianpdexta »
I cleaned the 'Salad cream' from the gear box and back end of my grey tractor by using a suds pump from a lathe stood in a washing up bowl with some paraffin, the bowl was positioned under the drain hole, I then had a length of garden hose with a nozzle attached to the pump, this way I was able hose out the interior with the paraffin. I probably used a paint brush to help to shift the stiffer deposits.
Obviously the recycling paraffin became quite dirty, so I changed it for some clean to give a the surface a final rinse and then mopped out what was left with a cloth. This left a nice clean red painted interior.
Ian
spike
Post by spike »
thank you ian
i did find a post from Brian using kerosene(not diesel bad for O rings) and oil mix (maybe paraffin will work as well) then driving round for around 3/4 of an hour then drain out and replace with new oil .(i am not taking the axle apart)
if i can find the post i will re post it
regards
spike
spike
Re: cleaning gunk from rear axle with Brian`s post
Post by spike »
Might be a good idea to use the Ford method of rear axle cleaning before you fill up with clean oil. Mix 1 gal. of oil with 2 gal. Kerosene, (Definitely not Diesel) and run around in the yard for 1/2 to 1 hour with no load. Then drain and fill with clean oil. This works for the gear box too.
anthonygos
Post by anthonygos »
spike wrote:thank you ian
regards
spike
Kerosene is usually called paraffin in the United Kingdom...! its what I have used for years and works well.
