a about h/shaft seals, is the easy one to do
the inner seal or outter seal i
have seen this seal called both :scratchhe
can confuse us lesser mortals
also is the te20 an s/dexta the same
half shaft seals
Re: half shaft seals
the first you come across is the inner seal this is the smaller of the two
the one behind the berning is the outter seal it is a lot bigger and alot more work
to renew, the te20 inner seal does fit the dexta if one was unable to get the right
one , the outter seal needs a dexta seal
