over size king pin bush
Posted: Mon Jun 12, 2017 12:45 pm
hi do you know if you can get over size bush for the king pins.
i took pin out to find 3 bushes, bottom bush ok top bush gone only 2/3 of it left and a bush that came out with a rag i pulled though.
the hole at top was oval and to big for the new top bush so i put the bottom new bush in as if fitted well, but inside hole was to big for the top of the king pin ( better then before), i did try to push the bush that fell out into the bush at top but was to tight then for the pin so taped it out.
so can you get over size on the inside to take up the play.
or any othe surgestions are always welcome
regards
spike
regards
spike
