"C" Model Light Switch
Does anyone have a source for a light switch part number 957E-11654-C? Or an aftermarket equivalent? I'm replacing all of the wiring, switches etc. in my 64 Super D. The only part I'm having trouble locating is that switch. There are plenty of the "B" model switches with the key but apparently not the C.
Delta Blue
Re: "C" Model Light Switch
WOOO HOOO. I took the old switch apart, cleaned the contacts inside, put it back together and it works just fine. To use the tractor the last couple of years I had installed a remote starter button and bypassed all of the electrical system. I didn't need lights and I was putting a battery charger on it after every couple of starts to keep the battery up. I'm putting in all new gauges and lights along with the new wiring. It will be nice to have it working the way it should.
Delta Blue
