Pulling out stock fence posts
MikesDexta
Post by MikesDexta »
I've got a number of 4" stakes and 6" strainers to take out of a sheep handling system I made last year as I want to modify it. They were thumped in by a contractor with a top end post knocker so are in solid; he can't come and pull them out as he is too busy. I've been told that my Dexta will pull them out using the 3 point linkage, a drawbar and a chain. I've seen it done with a TE20 on Youtube. Has anyone ever done this?
1959 Dexta
skipdow
Re: Pulling out stock fence posts
Post by skipdow »
I have done it with my dexta. The hardest part is getting a good grip with the chain in the limited distance of lift. It helps if you can wiggle the posts side to side a bit to loosen them.
oehrick
Post by oehrick »
Done it with a Major Mike so don't see why not with a Dexta, it depends on the bight in the chain getting a bite on the post before all the vertical lift is used up, of you use a D or C shackle and make a slipping noose the post will either come up a bit or snap. A noose in a steel rope may be better but it is not so easy to moor the other end without slippage or lost distance while tightening.
If you have a decent baulk of timber or say a bit of 4" - 6" I beam you could quickly fabricate a crane arm which would give more lift distance available but at the cost of less available force - a couple of cast Major wheels on the tombstone would help control any bucking bronco tricks the Dexta might try on you.
The other way would be to make an L shaped frame, fix the end of the horizontal bit to the post and hitch the drawbar to the top of the vertical bit, have a plank or something to spread the force of the angle it pivots on so it doesn't just dig into the ground, as you pull on the vertical the horizontal should rise bringing the post with it, I've pulled out some sizeable birch trees roots and all over the years using one about six foot on both arms / legs and IIRC about 8" I beam with some hefty box section as diagonal braces.
HTH & good luck
MikesDexta
Thanks both, I will first try the drawbar and chain but I'm not confident it will work on the 6 inch strainers as they are in so solid they don't move if I apply all my far too much weight on them so I am expecting the Dexta to buck. If so I will try Rick's suggestion. Weather permitting I will do this tomorrow and let you know how I get on.
cheers
Mike
1959 Dexta
