DRAFT CONTROL SPRING,BUSH AND SWIVEL QUESTION
Posted: Tue Mar 05, 2019 2:42 pm
I have a new draft control spring,bush and swivel for my dexta but i have a couple of questions - The reason being, all of the draft control fittings were not present when i removed my lift cover (i can only assume these were removed by a previous owner/cowboy)
1. Should the bush be a loose fit to slide into the swivel? (the bush i have just might fit into the swivel but would need to be pressed into it as it's very tight)
2. My draft control spring seems to butt against the bush, is this correct? OR should the spring fit inside the bush?
I purchased these from Agriline and they were listed as Dexta parts but i'm not sure if they are correct?
I have the new draft control link coming from USA as it was missing as well (nearly impossible to get this part now)
Your expertise will be very much appreciated with the above!
Thanks.
Thanks.
