Lights on Lambourne Cab - what a stupid design !
Posted: Tue Jul 30, 2019 2:43 pm
As the H&SE back in 2002 (ish) decided that ALL tractors need to have safety bars if working - whether it is your own farm or not - I need to replace the wings with the Lambourne which cam with the tractor.
However, the lights were removed from the cab wings.
I have taken the lens off to get access to the corroded and broken off stud only to realise that the studs are inaccessible and the rubber "gasket" at the bottom og the lamp is moulded and extrudes into the lamp workings so I think I am having to purchase new rear lamps
What numpty designed them I wonder ?
