Lever on injector pump
Scoobynorm
Post by Scoobynorm »
Im restoring a 1960 fordson dexta
Theres a lever on injector pump at the back between the pump itself and the engine.
Was wondering what is it for??
ianpdexta
Re: Lever on injector pump
Post by ianpdexta »
Hello
I think what you are describing is the speed control, i.e. throttle, try opening and closing the throttle under the steering wheel, and see if it moves.
Ian
A1960 dexta should have a vacuum governor and no direct connection between throttle and pump.
Isn’t it the bracket where the outer tube of the stop cable is clamped to?
It sounds like the stop lever, although that only applies to pneumatic governors. That is what was used from 1957 to May 1962, when the minimec was fitted. If you have a minimec (Not original for a 1960 Dexta) that will be the throttle lever, the stop lever being on the outside.
minimec pic (sorry, don't have a pic of the other pump)
Scoobynorm
How can i attach photo???
Try this.
viewtopic.php?f=1&t=5024
bobfaecullen
Post by bobfaecullen »
I think you are probably talking about the stop lever, it should have the pull to stop cable attached.
Bob
Scoobynorm
That's the stop lever, attach the stop cable to it. Pulling it back will stop the engine.
Scoobynorm
Thanks everyone, there was no stop cable on it when i got it, so i wasnt sure what it was..
Scoobynorm
Re: fuel line???
How do i know which one i require,
You have a pneumatic governor.
Be careful with repro pipes, we got one that we haven't fitted yet that is bent some 2" further back than it should be.
Scoobynorm
@sandy thank you
