I have just refitted my refurbished pump and injectors. When I fitted the fuel injector pipes (original) I now have small leaks at 2 of the injectors. It looks like the fuel is leaking from the thread at the union of pipe to injector. Is there a recommended sealant, or is it possible to redress the pipe ends? Any suggestions to stop these leaks.
Do not use sealer! If it gets into the pipe or injector you will be in trouble. If you cannot seal it by tightening then take the pipes to an injection specialist for new ferruls or possibly new pipes.
