Ford 5000 rear wing wiring
spannerdog
Post by spannerdog »
Does anybody have any good photos showing the correct ( ex Basildon) way the wiring under the rear wings of a Ford 5000 should be done?
I know the wiring runs up one of the centre supports of the wing and then splits to run to the front and rear lights along conduit formed at the wing end but what connectors are used?
Also the earth tag on the side lights is that earthed within the light? or does it earth under the wing.
Any of the photos that can be posted of the wiring will be most helpful
Thank you in advance.
