65 S-O-S
Wagtail
65 S-O-S
Post by Wagtail »
Hi everybody!
I've been lurking for some time. Since I finally decided to try my hand on restoring my 65 S-O-S it's time to de-lurk. I sure need help!
First question: LH floorboard is needed. NOS seems to be unavailable. The one used with constant mesh transmission seems to be quite similar to the S-O-S floorboard.
Is it possible to modify the constant mesh floorboard? At least I need to close the clutch pedal hole. What else, do mounting bolt patterns match up?
Please list some good parts sources. Messick's will get my first order but I would like to have more options to shop around. NOS/OEM parts preferred.
Edit: It's a 5000.
Thanks, Wagtail.
Re: 65 S-O-S
Hi Wagtail,
You need to give us a clue on where in the world you are.
I was pretty sure they used the same footboard for both SOS and standard transmission here in England but it is many years since I worked on them.
Wagtail
Re: 65 S-O-S
Post by Wagtail »
Hi Brian,
My 5000 was buit at Basildon early 1965 and I'm Europe.
Thanks, Wagtail
Wagtail
Re: 65 S-O-S
Post by Wagtail »
Hi again,
My 5000 is missing a rear view mirror. Was there a certain type istalled at Basildon? Or were they country spefic depending on their destination?
What should I look for?
Thanks, Wagtail
Wagtail
Re: 65 S-O-S
Post by Wagtail »
Okay, next question:
I believe the early seat cushions had "FORD" on them. Any time frame?
Wagtail
Re: 65 S-O-S
Rear view mirror was made and fitted in the dealership. we used a round mirror on a bent flat metal arm. Seats were not really seat shaped like the later ones. but did have Ford on a decal across the back on the metal.
Wagtail
Re: 65 S-O-S
Post by Wagtail »
Thanks Brian for the mirror info!
Our first 5000 had "FORD" across seat cushion. I remember it like yesterday. For a young kid it was the coolest tractor seat ever! My son and I have been looking for a decent one for last few months. So far we have seen half a dozen of them. None good enough for our purposes. Maybe it's time to order a repop.
BTW, tractors exporeted to Australia, were they built at Basildon? By looking at the mudguards it seems likely.
