removal of fuel sender unit 4610
rich2a
Post by rich2a »
hi, does anyone know how to remove the sender unit on a 4610 with q / bubble cab?
i have earthed the cable so proved the wiring and gauge, so by elimination the sender unit is most likeley u/s
any tips welcome, ta, rich.
1984 5610 FWD ,1981 ford 4610 ,1962 dexta,1959 power major, 1952 major, 1956 major, 1961 super major.
awemawson
Re: removal of fuel sender unit 4610
Post by awemawson »
If it's like the 4600 with a Q cab (and I think that it is) remove the instrument panel, and on the right hand side base you'll see a removable circular panel - 4 screws iirc - that lifts up. Under it is the sound deadening felt that has a corresponding disk part punched that removes. Under that is the fuel sender. It's a tight, small hole to work through but supposedly it's possible
Good luck
Sedlescombe
East Sussex
rich2a
Post by rich2a »
hi, ta for reply, i found the removable plate, but find it hard to belive sender unit will come out through it!!
rich2a
Post by rich2a »
hi, well sender unit is now out!!
far easier than i thought.
float was missing, and electrically dead!
thanks, rich.
