Hi all
I am new to this Forum and Im trying to ID a 4d engine year of manufacture ETC.
The info I have is as follows.
The rocker cover has_Model 2712E. CAP 4.150 LITRE. Date Serial No D8520/304. Build No 521/217/453/300.
The cast No on head is T1 743F6090AAA
The Block cast No is T2 703F 6015 AAA
The Block also has a circle with figures 1 to 9 around the perimeter with an arrow pointing to the figure 3,also under circle is cast 8B2
Any info appreciated
Norm
ford 4d engine
Re: ford 4d engine
I am searching for parts for a ford industrial dorset 254 c.i. diesel 4 cylinder that has the same block # that you posted (T2-703F-6015AAA). Are you selling by chance? Or looking yourself? I may be interested in parts (crankshaft specifically).
Re: ford 4d engine
Hi tm40
Sorry about delay in replying ,been away for several wks.
The engine is going into an old coles crane, replacing a very old 4d which had issues with porosity in liners or block or both even though it ran sweet. I don't know if the cranks are similar.
Norm.
Norm.
Re: ford 4d engine
Hi all
Ive just taken a ford 4d engine out of a 1956ish Coles crane 2712e going in.
The old engine has a sump with a cast lug with a hole about 1inch to 1-1/4 inches thru it.
The head has a decompression lever on it. also it has a starting handle facility on the end of the crankshaft.
I think it could have been a tractor engine at some time, any ideas anyone.
Norm.
Norm.
Re: ford 4d engine
the 4d sounds like an early major engine.
Does the throttle linkage go through the engine block itself?
How many studs on the cover plate of the injector pump? 4 or 8
Is injector pump vertical or leaning in towards the engine?
How wide is the fan belt 1/2" or 3/4"?
If there's a number on the casting above the starter motor check it out in the reference pages.
Re: ford 4d engine
Hi Neilarmo.
The throttle linkage dosent go thru the block, cover plate has 8 studs assuming that's the plate at the rear of the pump, the pump seems to lean towards the engine, forgot about fan belt.
The only numbers on starter side block are M3
1 2
On pump side numbers are E1A DDN 6015 G
0H6
Norm
1 2
0H6
Norm
Re: ford 4d engine
Hi all.
Stripped the old 4D.
The crank, pump, and head are OK. The engine suffered from porosity(Liners Im told). The engine is complete except for starter and fly wheel, so its up for offers.
Norm.
Norm.
