Pics of backhoe
Pics of backhoe
Hi everyone
Im started drawing a backhoe with sub frame mount for my super major, and i would be pleased if you could show me pictures of yours installments
And if their is anyone interested in the drawings when im finished, i will ask The fordson tractor pages if they will have them on the site
A picture of were im gone to so far
Kenneth
Kenneth
Fordson for life...
Re: Pics of backhoe
Looks great.
Wich program do you use?
Re: Pics of backhoe
Solidworkshenk wrote:Looks great.
Fordson for life...
Re: Pics of backhoe
Nice, You have even included a thumb. Most Handy. Dandy Dave!
Re: Pics of backhoe
Looks like you are pretty handy with SW. We use Solid Edge.
Re: Pics of backhoe
How are you planing to mount it?
The Major was very popular for backhoe-use here in Norwaty (County too). On almost every conversion I have seen, the u-channels connecting the front axle to the gearbox is replaced with a subframe extending down and back under the rear axle. This subframe is a part of the backhoe. The tombstone in the front is not used anymore. Front axle is mounted to t.he subframe. Hydraulic pump and tank is mounted in front. This arrangement is also used on the smaller units...
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
1964 County Super-4
1967 County 654
Re: Pics of backhoe
My plan was to mount it to the frame of the front loader, but with the opportunity to take it of and use the 3pfrode wrote:How are you planing to mount it?
Have u some pictures of them
Why dont the use the hydraulic from the tractor pump
Fordson for life...
Re: Pics of backhoe
Im using it at work, as a industrial techniques milling.. having 2 big cnc mills to play with and drawing i solidworks when their are workinghenk wrote:Looks like you are pretty handy with SW. We use Solid Edge.
Fordson for life...
Re: Pics of backhoe
Dave do your backhoe use the tractor hydralic or is there a pump installed???
Fordson for life...
Re: Pics of backhoe
My Back hoe is a Massey. It has a pump mounted in the nose in front of the engine and was installed that way at the factory. From memory, Is not the New Majors pump only around 3 gallons per Minute. The Fordson backhoes I have seen all run off of a similar front mounted pump. If memory serves me right, these are around 8 gal Per minute pumps. Dandy Dave!
Re: Pics of backhoe
could you not make it a pto pump?
or if you mounted it to the front you could link 2 systems together to have a greater LPM and live hydraulics
I like the design looks good but the slew pivot looks a bit light duty compaired with others. have you run stress tests on the model?
Regards,
Regards,
Re: Pics of backhoe
Looking it up, my Masseys pump is 21.5 gallons per minute running at 2000 RPM. A PTO pump would need a similar flow at 540 RPM.
Re: Pics of backhoe
Like the idea with the front pump, so it can feed power steering and the front lift im planing to makejohn.n wrote:could you not make it a pto pump?
Regards,
I havent maked a strees test yet because im not all happy with the design
I have changed the mainframe many time since i posted this first time
i also have changed the main boom to a curved one
Fordson for life...
Re: Pics of backhoe
Isn't that a lot of RPM, do you have the tractor at 2000 RPM when digging???Dandy Dave wrote:Looking it up, my Masseys pump is 21.5 gallons per minute running at 2000 RPM. A PTO pump would need a similar flow at 540 RPM.
Fordson for life...
Re: Pics of backhoe
No, I never run it at full throttle. It is just a listed rating for the pump. Although the RPM gage on the tractor goes to 2,700, 2000 RPM is not out of the question for the 3 cylinder perkins. Dandy Dave!
