We are currently upgrading the board. You might experience some issues while using the website.
As for this: New members will not be approved during this process.
Thanks for your understanding!
With Regards,
The Fordsontractorpages management.
New project - from a plough to a snow plough
porteous
Post by porteous »
Just bought the remains of a 3 furrow PM plough for very little on fleabay (frame only, no bodies).
Picking it up tomorrow with the idea of removing the inner and outer arms and mounting a snow plough on the centre arm, like a yard scraper. So far just an idea. Whether it's ready for Spring depends on just how rusty it is! I am going to make the blade out of an old 47kg gas cylinder split in half if I can find one (properly purged and safe!). Not sure about the blade angle, but I was thinking 20-30 degrees would do? All (sensible) suggestions gratefully recieved
project by CraigWales, on Flickr
