590E engine rebuild
590E engine rebuild
Hello,
I just joined the forum after having bought a Fordson Super Major based County Super 6 needing a total rebuild.
I need a new set of camshaft bearings and tried the firm ACL mentioned in an earlier post without any luck. Does anyone know of a source for these?
I was told brass bearings should not really be used due to the friction difference.
Does perhaps the four cyl. engine from the Super Major have camshaft bearings that are available and fit?
Thanks for any pointers.
Simon
Simon
Re: 590E engine rebuild
Welcome aboard Simon!
The cam bearings are bad news, unless someone has just recently started to make them again, or if you can find a shop that has a NOS set stashed on a shelf, you probably won’t find a set. I just put mine back together with the old bearings.
Post a few pics, we’d like a look at the old girl.
Pat
Pat
Tractor needs a complete rebuild - I'll post non-engine picures in a new thread.
Engine ran quite well considering and the camshaft bearings turned out to be just within spec after polishing up, so that was a relief.
Next issue was the crankshaft harmonic damper, which had almost no rubber left:
![Image](http://i1378.photobucket.com/albums/ah111/dswright/CSS_old_damper_on_engine_zps007d28a3.jpg)
Didn't want to run a rebuilt engine hard without crankshaft vibration damping, and not finding a better replacement, found a friendly english speaking firm in Lituania who will do a rebuild.
Look at http://www.elastomer.eu They turned it round in 10 days including postage and the result looks excellent, Time will tell.
Next issue is the injectors - they seem to have a different number to the Super Major ones and not in any present listing I can find.
Anyone know if the proper ones are available, or if the Super Major ones would do ?
Simon
Simon
I am currently rebuilding two 590E engines. One for my Super 6 sand one for a truck.
Late Super Major injectors are the same as late 590E applications. You can get the nozzles from Agriline.
Cam bearings are available here in Australia
ACl Part no 7C5757 Specs
http://catalog.acl.com.au/ACLWebCatalog ... &p=IT42365
Available here
http://www.sparespro.com.au/ford-510e-5416cc-ohv-diesel
The 4 cylinder engines were not fitted with camshaft bearings from new, the cam runs directly in the block.
I will let you know how I get on.
I see your engine is a 1965 casting. What is the serial number and engine number of your tractor? Mine is 15101 but it has had a replacement engine that was cast in 1967. I was not aware that 590Es were built so late for service replacements. My engine has D series connecting rods and the crank has a D series part number on the casting so it must have been machined from a D Series billet. The engine number is S746465
Steven
PS I just tore down a 590E that has run a big end. The block is serviceable but the oil pressure must have been terrible as it had number 1 cam bearing missing!! I cannot understand why the camshaft did not bend.
Available here
Steven
Thanks Steven for the information.
You are observant - the engine no is S513409, built end of 1965, Unfortunately it is a replacement and most other tractor ID indicators are long gone.
The rear gearbox block was cast mid 1964, so it is a late model, confirmed by the rear axles, shafts and gears being the heavy duty ones from the post major Ford being built then.
I can understand a small outfit like County scrounging and modifying a few bits, but surprised that Ford did not have proper replacement engine parts for the model that had only recently been replaced and around in large numbers!
Simon
Simon
Hi Simon
Good that there is one more Super Six here in Germany.
My Super Six had the same problems like yours.
Had to buy a good priced and running spare engine for my County,so the engine
problems are solved.
As fore the County ID number,mine is gone too.
but i found the original Fordson Skidunit number on the fronttransmissionflange
right under the Airfilter (just behind the starter).
08D966512
Now the question is: is it possible to get the right County ID number?
here are two photos
![Image](http://www.mijnalbum.nl/Foto-DTBVCRDG-D.jpg)
![Image](http://www.mijnalbum.nl/Foto-ZGMSUR33-D.jpg)
for Steven :
some people have no chance to get the Cambearings for their engines.
In your area they are easy to buy,can you help them ???
mbg Jan
08D966512
here are two photos
for Steven :
mbg Jan
Hallo Jan,
you could try to contact
http://www.atosborneltd.co.uk/page9.htm
in GB. They have the spares and documents of the County tractors. They might be able to give you Support. I orderd a new driveshaft for my County Super 4 almost two years ago.
Try to calll them, since computing is not their business![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Regards Matthias
With County, you can![Wink ;-)](./images/smilies/icon_wink.gif)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
1959 Power Major
1963 Super Major
1966 County 654
Hi Jan,
Nice to there that there is another Fordson based Super 6 in Germany:-)
As Matthias mentioned, it is a good idea to get in contact with AT Osborne Ltd.I spoke to them a couple of days ago and Mark told me, that i should look for a number between the engine and the fuel tank. Your's looks like this number, so if you are lucky, Mike might be able to trace it... If you are not so fluent in English, I can do it for you.
Why not post a photo showing the complete tractor
. Unfortunately I didn't make one of mine before ripping it apart ![Sad :-(](./images/smilies/icon_sad.gif)
Simon
Simon
Hi Simon
As for the phonecall,i think my english in a call is not the best.writing is another thing.
so it will be better if you try to find out the id nummber.it will be really good when you do this for me.if you have problems with your county,and need a closer look on a running one,you are welcome for talk and look.i lliving in the north (60km south direction from bremen )
![Image](http://www.mijnalbum.nl/Foto-BSUKTULL-D.jpg)
here are some photos
![Image](http://www.mijnalbum.nl/Foto-LJ8LANHS-D.jpg)
![Image](http://www.mijnalbum.nl/Foto-ONZCIFUG-D.jpg)
![Image](http://www.mijnalbum.nl/Foto-YQUEQXNB-D.jpg)
mbg jan
mbg jan
[quote=
for Steven :
mbg Jan[/quote]
Hi Jan
Firstly, thank you for the tip on that number location. It appears that Super 6 skid units were ordered from Ford without and engine so Ford put their serial number on the gearbox. Makes sense. I often wondered if they were delivered with a 4 cylinder engine and County sold those engines off. Not so.
My tractor is 08D968835. The County serial number is 15101.
To your question regarding cam bearings. They are not as easy to get as it first appears on the website I posted. I have just got 3 sets coming in and I will be buying a supplier out shortly with another few sets plus he has some 10thou sets as well. I need at least 5 sets for my foreseeable projects. I am placing a large parts order with Agriline shortly was thinking If they are agreeable maybe ACL will make a run for them or I can send a set to them so that they can get them made by their current supplier. I would say ACL would need an order of 100 to 1000 sets to make the business case. I will update shortly.
Steven
for Steven :
mbg Jan[/quote]
Hi Jan
Steven
hi Simon
i send you a PM please read it
mbg Jan
mbg Jan
