Page 5 of 7
Posted: Sun May 09, 2010 6:36 pm
by aviator
JC wrote:You're a very good steel fabricator, aviator. When are you going to start moving logs?
Thank you
. When I get the table that the valve gear ready, install the loader hydraulics. After that I get to test how the tractor and loader to behave terrain. I tested my tractor in the forest some time ago and I will continue the project forward.
Posted: Mon May 10, 2010 10:21 am
by aviator
The loader valve rack table installed.
Posted: Thu May 13, 2010 10:26 am
by aviator
Hydraulics 1.
Posted: Sun May 16, 2010 5:50 pm
by aviator
Hydraulics 2.
Posted: Sun May 16, 2010 11:54 pm
by Mark
Your fabrication techniques are very good Aviator. Soon you will be out in the log woods.
Mark
Posted: Tue May 18, 2010 3:19 pm
by aviator
Hydraulics 3.
Posted: Tue May 18, 2010 7:07 pm
by aviator
Mark wrote:Your fabrication techniques are very good Aviator. Soon you will be out in the log woods.
Mark
Thank you
. As long as I control the loader hydraulics constructed, then is the time of the first tests. I await impatiently for the time this shell that I will get to test the tractor after a long construction project.
Posted: Fri May 21, 2010 4:54 pm
by aviator
Hydraulics 4.
Posted: Sun May 23, 2010 11:54 am
by aviator
Hydraulics 5.
Posted: Wed May 26, 2010 6:00 pm
by aviator
Hydraulics 6.
Posted: Sat May 29, 2010 12:00 pm
by aviator
Forest tractor will test the use of seat. Might require a bit more development of the final version ..
Posted: Sun May 30, 2010 7:17 am
by JC
I like the seat. I have a lot of those, now I know what I can use them for.
Posted: Mon May 31, 2010 4:17 pm
by aviator
Forest tractor project will now move on their summer holidays. Still needs to be done, such as logs Changing hydraulic winch, tractor weights bow, seat, charger installation, electrification of the tractor, cabin interior design, painting, etc. .. So the story continues ... Thank you to all who have been interested in the progress of the project and the good / hot summer.
Posted: Sat Oct 30, 2010 7:02 pm
by aviator
Summer break for the project is over. Forestry tractor is coming during the winter test period. Yet it has not been the actual forest runs, only twigs and transport of frames. The winter test phase must be very clear from the final structure and changes.
I begin in the coming days a new chain of tools and implements forum related to this project 2 phase.
http://koneenkuvia.blogspot.com/
Posted: Sat Oct 30, 2010 11:02 pm
by Bensdexta
How heavy is the biggest log your hydraulics can lift?
Great work - look forward to seeing it working
Posted: Mon Nov 01, 2010 5:57 pm
by aviator
Bensdexta wrote:Hi,
I do not have the crane operator's manual lifting force which could be read, and I have not yet brought the timber crane, so I do not know. But during the winter as long as I get to test the lifting and transporting of logs, both at the same time shows how powerful crane is.
Posted: Wed Nov 03, 2010 3:44 pm
by aviator
Re: Forest Tractor construction
Posted: Tue Dec 28, 2010 6:06 pm
by aviator
The capin interior of manufacturing 1.
Posted: Sat Jan 01, 2011 4:24 pm
by aviator
The capin interior of manufacturing 2.
Posted: Tue Jan 04, 2011 6:07 pm
by aviator
The capin interior of manufacturing 3.
Posted: Sat Jan 08, 2011 5:46 pm
by aviator
The capin interior of manufacturing 4.
Posted: Sun Jan 09, 2011 7:45 am
by JC
You're doing a nice job. That should make it warmer and quieter.
Posted: Tue Jan 11, 2011 4:37 pm
by aviator
JC wrote:You're doing a nice job. That should make it warmer and quieter.
Thank you
. The interior of the material is RP-240 ABS- plastic. The same plastic is used in some John Deere forest machines in cabs. It's really a shock-resistant, even in the cold, so it takes a good use.
Posted: Tue Jan 11, 2011 5:08 pm
by aviator
The capin interior of manufacturing 5.
Posted: Sat Jan 15, 2011 5:39 pm
by aviator
The cabin interior of manufacturing 6.
