Forest Tractor construction
Postby aviator » Sat Feb 20, 2010 11:13 pm
Traction device installed.
aviator
Postby aviator » Mon Feb 22, 2010 10:08 pm
Cab at the front of the building 1.
aviator
Postby aviator » Wed Feb 24, 2010 11:42 am
Cab at the front of the building 2.
aviator
Postby aviator » Fri Feb 26, 2010 9:50 am
Cab at the front of the building 3.
aviator
Postby aviator » Sun Feb 28, 2010 4:53 pm
Cab at the front of the building 4.
aviator
Postby aviator » Mon Mar 01, 2010 6:16 pm
Steering arm
aviator
Postby aviator » Thu Mar 04, 2010 6:53 pm
Steering arm 2.
aviator
Postby aviator » Sun Mar 07, 2010 9:29 am
protective bars on the windows 1.
aviator
Postby JC » Sun Mar 07, 2010 7:49 pm
You are doing a really nice job. Thanks for all the pictures.
JC
Postby Dandy Dave » Mon Mar 08, 2010 2:38 pm
I've been watchin too, currious how you are going to hook up the steering arm, and still keep the cab sealed. Looking good. :D Dandy Dave!
Postby aviator » Tue Mar 09, 2010 10:40 am
JC wrote:You are doing a really nice job. Thanks for all the pictures.
Thank you for your compliment. :D
aviator
Postby aviator » Tue Mar 09, 2010 10:58 am
Dandy Dave wrote:I've been watchin too, currious how you are going to hook up the steering arm, and still keep the cab sealed. Looking good. :D Dandy Dave!
Deleted at the bottom of the window I cut a piece off, when the window should be slightly lower. Then drag link can move freely. Hole from which the drag link will summarize rubber out of the cabin, the cabin when the tightness is maintained and still get the drag link to move freely.
aviator
Postby aviator » Wed Mar 10, 2010 10:30 am
protective bars on the windows 2.
aviator
Postby aviator » Sat Mar 13, 2010 7:51 am
Protective bars installed on windows.
aviator
Postby aviator » Wed Mar 17, 2010 6:12 pm
New parts of the order was received.
aviator
Postby Ian » Thu Mar 18, 2010 12:32 am
Is it a prison tractor ? You got enough bars on the windows ;) Nice project though, looks like you are progressing really well.
Ian
Postby Dandy Dave » Thu Mar 18, 2010 1:14 pm
Ah yes. So you are going to add power steering. Cool 8) You will have to fill us in on how well the kit fits, and works. :D Dandy Dave!
Postby aviator » Sat Mar 20, 2010 5:33 pm
Ian wrote:Is it a prison tractor ? You got enough bars on the windows ;) Nice project though, looks like you are progressing really well.
Yet I will be installing electronic locks on doors that open only when the work day is completed. :lol:
aviator
Postby aviator » Sat Mar 20, 2010 5:41 pm
Dandy Dave wrote:Ah yes. So you are going to add power steering. Cool 8) You will have to fill us in on how well the kit fits, and works. :D Dandy Dave!
Booster series, at least externally, seems quite good quality. I think it works quite well. But if it works as it should, so it is certainly a great help.
aviator
Postby aviator » Sat Mar 20, 2010 9:58 pm
Traction device protection plate 1.
aviator
Postby aviator » Mon Mar 22, 2010 10:06 pm
Traction device protection plate 2.
aviator
Postby aviator » Fri Mar 26, 2010 11:18 am
Protective plate installed.
aviator
Traction device
Postby Bensdexta » Fri Mar 26, 2010 12:30 pm
aviator wrote:Protective plate installed.
How does the traction device work?
Your engineering is first class :wink:
Re: Traction device
Postby aviator » Sat Mar 27, 2010 5:25 pm
Thank you :) . I removed the tractor to lift hydraulics altogether. Blocked the wagon, where the loader is connected to the towing device hooked. The tractor will only use the forest, so the wagon did not have to disconnect the traction device, but it is there permanently in place.
aviator
Postby aviator » Mon Mar 29, 2010 4:35 pm
Mudguards removal.
aviator
PreviousNext
Who is online
