Fordson Oil Filter
Fordson Oil Filter
Postby chris88 » Sun Jul 11, 2010 10:06 pm
I'm currently fitting a ford 2702E into my FMD and i am having trouble with my oil filter housing i have had mew side rails made so i really dont want to cut them for my oil filter housing so i was wondering if there was a way round this
chris88
Postby Scruff » Sun Jul 11, 2010 10:30 pm
I dont know the layout of this engine but I have seen a solution on another engine that might help.
He made a blanking plate where the filter housing bolts on with hydraulic hose fittings welded to it, then hydraulic pipes away to somewhere where the filter housing will fit above the side rails.
Just a thought.
Scruff.
May all your dreams be blue !
Scruff
Postby essex pete » Sun Jul 11, 2010 10:53 pm
I know you don't want to cut it but there hsve been pictures either on here or the Brit Farming Forum (classic) with a very neat dog-leg for the filter. Just a thought. Is that a 4cyl engine? It will tranform the performance although some purists would not agree!
essex pete
Postby fergusont20 » Sun Jul 11, 2010 11:42 pm
Hello
Im fitting a Ford 2713E industrial engine 5950cc 363 cu in, into my major, have a look here http://www.fordsontractorpages.nl/phpbb2/viewtopic.php?t=1235
I dont know the 2702E engine but im guessing that if you say you have changed the side rails, the new engine is 6 cylinders and longer??? the oil filter which came with my 6 cylinder engine was too big and i too would of had to cut some metal out of my new side rails, i didnt want to do this so i used the original oil filter off my 4 cylinder engine, this just fits without any cutting of side rail.
If the above is not possible make or buy a suitable remote oil filter setup, whereby as already mentioned you have a plate bolted to engine block where the oil filter would normally be, then you run two hoses up to your oil filter which is mounted out of the way of your side rail, this saves cutting siderail. I was going to design a remote setup for mine untill i found the 4 cylinder filter just fitted.
Hope this helps, and also if you have some pictures,,,,, let us see them :)
Mark
here is a picture of my 4 cylinder oil filter just fitting inside the new siderail of my new 6 cylinder engine - hope this helps you
fergusont20
Postby chris88 » Mon Jul 12, 2010 8:19 pm
hi it is a 6 cylinder i saw your post with the 4 cylinder oil filter on the only worry i had was a loss of oil pressure i was told that lloyd loaders had a adaptor plate for a muirhill that would turn the oil filter through 90 degrees so it is above the side rail but this costs £144 so i wanted to make sure it would work
chris88
Postby Gubbels » Mon Jul 12, 2010 8:35 pm
I am also fitting a 6 cilinder 2700 series engine in my major. I just made a gap in my new side rails, but I made the side rails out of 8mm steel instead of 6mm. Are your afraid of the strength or the looks of it?
You can have a look at my project here so you can see my solution:
http://www.fordsontractorpages.nl/phpbb2/viewtopic.php?t=1612
I am looking forward to seeing some pictures of your conversion. good luck with it.
Regards,
Arno
Restoration project: Fordson Power Major 6 cyl. Conversion http://www.fordsontractorpages.nl/phpbb3/viewtopic.php?f=9&t=1612
Gubbels
Postby chris88 » Mon Jul 12, 2010 8:46 pm
a bit of both really ive seen alot of conversions where the side rails have been cut and not meaning to offend any one but they dont look right in my opion and the thing that flashes up in my mind is that any where that you cut the side rails is goin to cause a weakness
chris88
Postby fergusont20 » Mon Jul 12, 2010 9:40 pm
Good luck, and keep us updated with whichever option you choose to go with, I'm sure a smaller filter with less surface area for the oil to pass through will cause a greater oil pressure
fergusont20
Postby Pascal » Wed Jul 14, 2010 6:05 pm
Hi Chris,
I am using an 4 cilinder oil filter (the long version) on my 590e six cylinder.
Should work fine, and it fits between the side rails.
Good luck.
Best regards,
Pascal
Pascal
Re: Fordson Oil Filter
Postby 1962 model » Sat Jun 25, 2011 6:08 am
Hello all,
I have heard that the short Power and Super Major oil filters do not have enough oil capacity for the 6cyl engines, Like Pascal said, use the long one only.
Mike
1962 model
Postby super6 » Sun Jun 26, 2011 10:28 am
i do not know if it is best practice but i have seen one that was turned upside down.
super6
Postby BearCreek Majors » Sun Jun 26, 2011 1:19 pm
Chris, in Brians "tractor tour" there are pics of several converted majors. One in particular that caught Brians eye has the filter mounted outside of the frame rail with a extended adapter, it looks a little diferent but its got to be a lot easyer to chang the element.
Pat
viewtopic.php?f=7&t=3188
BearCreek Majors
Postby chris88 » Mon Jun 27, 2011 7:38 pm
Hi everyone thanks for the replys i ended up getting a part off of a county that moves the oil filter up behind he injection pump as soon as i get time i will post some pictures
chris88
Who is online
Users browsing this forum: No registered users and 2 guests
