590E camshaft problem
Posted: Fri Jul 01, 2011 12:39 pm
Hello all,
I have just removed the camshaft from my 1962 590E and found that there is a problem with the endfloat as the thin thrust flange on the cam seems to be worn.
Is there a simple fix or do I have to replace the cam? ( there was no gasket under the front plate )
Mike
Been doing more research, the 6cyl seems to reflect camshaft changes of the 4cyl, which means any front plate change to suit a tractor conversion would need one from the same era tractor.
The 1962/3 camshafts were a problem because they had very little effective thrust surface which was prone to wear, Ford supplyed 3 to 5 thou shims to make an adjustment hower these would not be hardened and not be long lasting either.
I am considering swapping to a different model cam, the earlier one would require a gear change due to the fifferent gear mounting method, I will have a look at a later one from 1965 to see if it is more compatable.
The 1960 cam thrust was a much better idea, why Ford had to change it I have no idea?
Mike
Mike
Mike
