This and that about Ford 590E engines.
Postby super6 » Sat Mar 13, 2010 6:39 pm
hi guys great thread
i was wondering how much oil you use to fill your 6 cyl engine, i have been guessing mine as it came with no dipstick, my sump has the deep area at the flywheel end.
super6
Postby fergusont20 » Fri Mar 19, 2010 10:45 am
Following on my thread in the major forum about me wanting to put a 6 cylinder turbo engine in my recently acquired major.
I have been doing alot of thinking about this and i have decided to try and source a 590e engine for it, i know these dont have turbo's but echoeing what alot of older and wiser people on here have previously said, ive been thinking, do i really need that much power? so i think a 590e engine will be more than enough.
So for the last four days i have been seeking to buy an engine, i purchased the vintage and classic commercial magazine and have rang quite a few advertisers in there, i havnt turned up too much though. There is a place near luton with several engines, free standing and still in chassis, i have been told by a few people that these have been standing outside for a long time, so may be alot of trouble. I have a person trying to source me an ex ministry of defence one, which you would hope will have been serviced very regularly and not seen much work.
In the meantime does anyone in the uk know of any reasonable 590 engines for sale??
Thanks Mark
fergusont20
Postby fergusont20 » Wed Mar 24, 2010 8:22 am
I went to look at that commercial breakers yard yesterday, 1000's of trucks and 1000's of various makes of engines all exposed to the elements :( I found two 590e but they were too far gone, been standing outside for many many years, why o why were they not put under cover. What a waste !
If i had wanted an engine from out of a d series or an ford cargo, both of which were lying on there side. i had the choice of about 100 of them. Typical !
So im still looking for an usable/running 590e engine
Im learning, but not yet 100% with all these engines numbers and what they were in. Am i right in thinking?
Fordson major - 4 cylinder diesel - called 4d
Ford thames trader - 6c Diesel version - same as major called 6d, engine number 590e
Ford d series truck/(custom cab?) - Are these engines the 2700 series? which are 45 degress on the slant?
I was reading through an older tractor magazine this morning, there was an article about a ford county, it said the original engine was knackered and was replecd with an identical one out of an clayson combine harvester it said it was a 2713E, the picture looked like a 590e and i thought clayson combines had 590e's??? im confused?? :?:
fergusont20
Postby fergusont20 » Wed Mar 24, 2010 11:58 am
Sorry for all the questions, im 28 years old and if i dont ask alot of questions i dont learn :D
I just found the above picture on a gasket website , it lists the 590e as a d series engine, does this mean these 590e engines were also put on there side in d series trucks aswell as being upright in the thames traders? or is a "dorset 590e" from 1965-68 different to the earlier ones?
If that is correct i presume i need to make sure that i get one which has definantly been standing upright out of a trader.
Is it me or is this not the most straightforward of topics??
fergusont20
Postby Brian » Wed Mar 24, 2010 2:44 pm
The 590E was never a "D" series engine. The 590E came from the Thames Trader lorries from around 1960 to 1965.
The "D" series was an under-cab unit and was inclined. It was also a short stroke engine. It was similar to the 2700 series industrial engines.
Postby fergusont20 » Wed Mar 24, 2010 3:12 pm
Thankyou for clarifying that Brian, so that picture above that i took from a gasket website is incorrect?
fergusont20
Postby Pascal » Wed Mar 24, 2010 8:14 pm
Hi Fergusont20,
What a shame to see such 590E's rusting away... :cry:
I hope you will find a good engine.
Best regards,
Pascal
Pascal
Postby fergusont20 » Wed Mar 24, 2010 9:56 pm
Pascal wrote:Hi Fergusont20,
Thanks Pascal
I too hope i can find a good engine, normally sourcing items is not too difficult but struggling with this engine, i have many people on the lookout for me so fingers crossed. There is a farm sale im going to on friday, there is a irrigation pump listed with an 6 cylinder engine, wonder if its a 590e?? There was one thames trader still with an 6d engine in where i went yesterday, only problem is truck was behind about 30 other trucks with no real gap in between, ive no problem removing it from truck but not sure how i would get to to the main track? the main man was not there but i think he wants quite alot for everything he sells, and also the truck has stood there a very long time, engine has been covered by cab so not sure how much it would take to run, what does everyone think?
Thanks Mark
just thought, im actually 27 not 28 :D
fergusont20
Postby Pascal » Thu Mar 25, 2010 7:16 am
Hi Mark,
These 590E's are indeed quite expensive. Here in The Netherlands there are about 500 - 1000 Euro's.
Luckily I got mine for free from a relative. But it needed a complete overhaul. I think I have spend a couple of hunderd Euro's on replacement parts and straightening the head.
But now I hope to have a good ans new engine! :D
I hope to have it running in May!
I believe, that the big advantage of a 590E is, that all spare parts are pretty easy to find. Maybe it's an idea to try to find a relatively cheap engine and then rebuild it? It would be nice though, if you could turn the engine around by hand (so it's not stuck) and see if there's no damage because of the frost.
Good luck!
Best regards,
Pascal
Pascal
Postby The Swanndri Guy » Fri Mar 26, 2010 1:00 am
Hi fergusont20, just a thought,but those two 590e engines you saw at the breakers yard that you say are to far gone.If nothing else is available, is there any chance that you could aquire both engines,( at the "right" price) dismantle both and rebuild one good engine from the two? I've heard stories of Fordson engines that have been "reclaimed" from being buried in rubbish dumps that have been rebuilt and reused succesfully. :yeah: TSG
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
The Swanndri Guy
Postby fergusont20 » Sat Mar 27, 2010 11:42 am
The Swanndri Guy wrote:Hi fergusont20, just a thought,but those two 590e engines you saw at the breakers yard that you say are to far gone.If nothing else is available, is there any chance that you could aquire both engines,( at the "right" price) dismantle both and rebuild one good engine from the two? I've heard stories of Fordson engines that have been "reclaimed" from being buried in rubbish dumps that have been rebuilt and reused succesfully. :yeah: TSG
Both had no oil filler caps for full of rain water, all metalwork really coroded, injector pumps tatty with badly coroded driveshafts, starters and dynamo didnt look very pleasing,both rockercovers coroded away, both bellhousings exposed and looked reallt poor state. I dont think they would of been cheap either.
Id really like one i can see running, or ones thats been undercover and turns over by hand. Id rather pay more for a good one.
Got a new contact yesterday, man who deals in old engines, i rang him and he had a 6d but sold it last week, he's trying to source me another one so fingers crossed.
fergusont20
Postby Grani » Thu Apr 01, 2010 1:25 pm
I could buy some more too. :lol: One is dismantled at the moment and was not able to join the Ford engine concert today.
http://www.youtube.com/watch?v=cBCcLipy3wU
Grani
Postby super6 » Thu Apr 01, 2010 7:26 pm
now your just showing off :lol: :lol:
super6
Postby Pascal » Thu Apr 01, 2010 7:36 pm
I love it when Grani is showing off! :D :clap:
I see him as a choirmaster of several "6 men orchestra's"! 8)
Best regards,
Pascal
Pascal
Postby Grani » Thu Apr 01, 2010 7:38 pm
super6 wrote:now your just showing off :lol: :lol:
:mrgreen:
Grani
Postby Mark » Sat Apr 03, 2010 5:23 am
Grani,
That's "Sweet" four 6cyl, and one flat head V8 running all at the same time.
I used to own a flat head V8 in a 1950 Crown Victoria Ford, a great car. I have a 4 cyl flat head in my jeep. You don't see them much anymore, most of them went to the scrapper.
Get one more Grani and you will have a small orchestra playing in your backyard. :clap:
See ya
Mark
Mark
Postby Frans » Mon Apr 05, 2010 7:42 pm
Well I ve made a new hood decal for the 6 cyl
The big one is the size off the Power/Farm major badge
small one for the nose cone, I am not sure where I put them
regards Frans
1964 NP Super Major
Frans
Postby Frans » Mon Apr 05, 2010 7:44 pm
Maybe this is better
regards Frans
1964 NP Super Major
Frans
Postby Grani » Tue Apr 06, 2010 2:01 pm
Nice :lol:
Grani
Postby Pascal » Tue Apr 06, 2010 5:30 pm
Great, Frans! :thumbs:
How's your 4WD doing?
Best regards,
Pascal
Pascal
Postby Frans » Tue Apr 06, 2010 7:43 pm
The 4 wd is still sleeping under a blanket in the shed, I dont have a workshop were I can take her to do the things that must be done.
The weather was to cold to do some small things too so the next week I am going to Intermodelbau in Dortmund Germany and than I will be working on her again (small spring break with the kids) and than the show from our tractor club http://www.ewijksebrug.nl/historisch_weekend.htm
regards Frans
1964 NP Super Major
Frans
Postby henk » Tue Apr 06, 2010 8:10 pm
Looks like a nice event Frans.
Postby fergusont20 » Wed Apr 21, 2010 8:31 am
Im going to look at a 590E engine in a couple of hours time, i will let you know how i get on, the owner tells me it is a late 590e and that the injector pump is externally driven but different to the earlier ones, i wont know untill i see it. does this sound viable??
fergusont20
Postby fergusont20 » Wed Apr 21, 2010 8:46 pm
Ive brought an engine for my major, can anyone give me anymore detail about it
http://sites.google.com/site/fergusont20/pug/DSCF0527.JPG
http://sites.google.com/site/fergusont20/pug/DSCF0525.JPG
Stamped on the block just above the sump, manifold side:
http://sites.google.com/site/fergusont20/pug/DSCF0536.JPG
On the inlet manifold:
http://sites.google.com/site/fergusont20/pug/DSCF0532.JPG
Im told it came out of a very late thames trader, but i think its an industrial version (upright) 2700 series (d series) then again i dont know alot about these ford engine models
Looking forward to fitting it, will post more when i have more time, looking forward to finding out year of manufacture and anymore info
Thanks Mark
fergusont20
Postby Brian » Wed Apr 21, 2010 9:22 pm
That is either a 2703, 2704, 2713, 2714 ; You would need to see the information plate usually stuck on the clutch housing or on the bonnet.
Totally different engine to the 590E, This one has dry liners.
It looks like it came from something like a County.
PreviousNext
Who is online
Users browsing this forum: No registered users and 2 guests
