Ford County 1164
Ford County 1164
Postby billgatt » Wed Jul 31, 2013 8:03 am
Just bought a Ford County 1164 with Jones twin drum winch and timber front blade. She is in running order but will need restoring, usual County wear but not as bad as some. Im not a timber guy so would want to make it Agric spec which means I need the 3 point linkage. I understand these were based on the rear end of a Ford 5000 so Im on the hunt for any lift parts to convert including the lift top. I could sell the winch to off set cost of the parts. Please let me know whats out there.
billgatt
Re: Ford County 1164
Postby county654 » Wed Jul 31, 2013 4:27 pm
Congratulation to your deal.´
In order to get some advice, it might be a good idea to tell us the region where you are located 8)
Regards Matthias
With County, you can ;-)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
county654
Postby frode » Wed Jul 31, 2013 7:49 pm
Nice find! Please put up some pictures. I think that your "Jones" winch actually is a Norwegian made Igland unit. I may have some linkage parts for you, located in Norway though ;)
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
frode
Postby billgatt » Wed Jul 31, 2013 9:26 pm
I'm based in Aberdeenshire Scotland in the UK. I dont have a photobucket account as yet so unable to post pictures.
billgatt
Postby county654 » Thu Aug 01, 2013 7:18 am
If you are located in Scotland, check ebay.uk
Regards Matthias
1959 Power Major
1963 Super Major
1966 County 654
county654
Postby Stew1174 » Tue Aug 06, 2013 7:16 pm
what linkage you need depends on the age of your 1164 as there were 4 different build specs over the years.
prefix year engine model back end
8F 1971-1975 8000 5000
28F 1975-1979 8600 or 8700 7600
41F 1979-1982 TW10 7600
55F 1982 on TW10 7610
Hope this is helpful.
The best bet is to look for local tractor breakers or exporters
Stew1174
Postby billgatt » Wed Aug 07, 2013 12:20 am
Yes local breakers would be best but unfortunately none of them have anything meantime so Im just widening my search. There is a local guy with a 654 County, very poor condition with a front blade and a Hiab that has a lift cover and the cow horn arms still on it. I think it expensive at £3000 as the front left hub is burst, the engine barely runs and all the tin work is terrible. Maybe I should buy it anyway and take off the lift top with cross shaft and cowhorns then sell off the rest. Do you think the remainder would get me much money, the engine is the later 5000 cross block and of course there would be the other hub, drive shafts and gearbox which could be sold. What about front blade and HiAb?
billgatt
Postby frode » Wed Aug 07, 2013 9:03 am
billgatt wrote:Yes local breakers would be best but unfortunately none of them have anything meantime so Im just widening my search. There is a local guy with a 654 County, very poor condition with a front blade and a Hiab that has a lift cover and the cow horn arms still on it. I think it expensive at £3000 as the front left hub is burst, the engine barely runs and all the tin work is terrible. Maybe I should buy it anyway and take off the lift top with cross shaft and cowhorns then sell off the rest. Do you think the remainder would get me much money, the engine is the later 5000 cross block and of course there would be the other hub, drive shafts and gearbox which could be sold. What about front blade and HiAb?
contact the scottish county tractor club. they should be able to help you out.
frode
1964 County Super-4
1967 County 654
frode
Who is online
