don't worry about the power hurting the back end you'd probably be surprised what that tractor would take in short bursts
there have been a few different motors added over the years, seem to remember about guys putting an older 6 D fordson and other perkins engines in.
Why not go 3 cyl turbo. would make it a pocket rocket. Had a MF 135 in college turboed it would spin the tires, from standing start if the yard was wet
I seem to remember guys saying that the bonnets a pig to extend if going more cylinders. It is tapered so you can't cut and weld 2 bonnets easily like with the major conversion
I guess the other thing is that you need front axle mountings on the oil pan, or would have to fabricate supports from the back forward to carry the axle
Try searching youtube and see whats on there for ideas, I think there is a p6 perkins Dexta on there in the back of my memory when searching for something else
