roadless conversion
roadless conversion
Postby d.andersen » Fri Mar 14, 2014 9:46 pm
hi
on the super major ,there is different gear-ratios. Before 1963 ratio (orange blue) and after 1963(n/p) where it wass 4,375-1 and optional 3,5-1 .
does that give any problem if I want to put it together with a roadless kit ??
Fordson forever
d.andersen
Re: roadless conversion
Postby dexta roadless » Fri Mar 14, 2014 11:08 pm
Hello
Yes you need to have the same ratio. I guess roadless used different gears inside the gearbox to solve that
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
dexta roadless
Postby d.andersen » Fri Mar 14, 2014 11:33 pm
Ok ,but is the transfer box not mounted after the transmission ?
Fordson forever
d.andersen
Postby super6954 » Sun Mar 16, 2014 1:42 am
Something tells me there are different front tire diameters for what size tire is mounted on the back, to keep the ratio between front and back the same :idea: Don't know much about the Roadless but think there was an article in Vintage Tractor and machinery Magazine, a few years ago discussing this with diff ratio's and tire sizes, and what fitted what combinations :wink: . I should have it here but will take a while to find it , unless somebody else has it laying around :idea: .
super6954
Postby Roadless63 » Sat Mar 22, 2014 11:39 pm
the ratio is different in the final drive (differential) so this comes after the 4wd drop box hence you need the right gearing for your final drive or probably easier to find the correct rear diff ratio to match whatever roadless kit you have
Roadless63
Postby d.andersen » Sun Mar 23, 2014 12:02 am
Ok thanks
But if the roadless come from a 61 super major ,
And put on a 62 rear end, then the ratio should be correct.
Since the ratio dont change until 63 (n/p grey blue )
Am i not correct ?
Fordson forever
d.andersen
Postby Brian » Sun Mar 23, 2014 9:22 am
Yes, the ratio changed in the 1963 New Performance Supers to give more gears at PTO speed. We had one customer who we had to swap crown wheel and pinion every ploughing season to the 4.4 ratio and then, in Spring back to the 3.3.
With all Roadless it is the front tyre size that matters and, in theory, they should be the same size, make and type that were fitted at the factory. The reason was that different makes of the same size tyre had different rolling radius. This would again change if you fitted cross ply or radials.
Postby d.andersen » Sun Mar 23, 2014 11:00 am
Brian wrote:Yes, the ratio changed in the 1963 New Performance Supers to give more gears at PTO speed. We had one customer who we had to swap crown wheel and pinion every ploughing season to the 4.4 ratio and then, in Spring back to the 3.3.
So if I understand you correct , my setup will not give any trouble regarding
the ratio ?
My tires are 9.5-24 front and 16.9-30 rear
is the roadless ratio different on the greywing super majors ?
Fordson forever
d.andersen
Postby Brian » Sun Mar 23, 2014 12:34 pm
Yours should be OK. One of the New Performance would have the same ratio as yours, 3.3, the other would have a different ratio.
Postby d.andersen » Sun Mar 23, 2014 1:25 pm
Ok thanks ,
Fordson forever
d.andersen
Who is online
Users browsing this forum: No registered users and 2 guests
