Ford 6610 power steering
Postby Crawlerlad » Sun Jan 10, 2016 9:51 pm
hi all, I have a ford 6610 2wd with tanco 878 loader, she has always been good at steering but just lately when I get a haulage bale on the front she is hard to steer, does anybody know what the problem is
Crawlerlad
Re: Ford 6610 power steering
Postby SkidRoe » Thu Feb 11, 2016 7:52 pm
What steering set up do you have? Is it full hydrostatic, or is the steering box under the fuel tank with a drag link to the front axle?
I would likely start with the pump. Check the fluid level in the reservoir and make sure the filter is not collapsed.
Most hard steering issues that I have had on any of our Fords has been a result of a low fluid level.
HTH - SR
SkidRoe
Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Who is online
