Can You Still Get The GMC Axle They Used On Roadless Tractor
Postby redgiant » Thu Aug 04, 2016 10:46 pm
I think I read somewhere that it was a very common axle and that it was used on a variety of trucks etc. for a number of years. I'm guessing most of the ones that are still knocking about are in the States? I know it might seem like an utterly mad idea but hey, Roadless tractors are expensive and I want one bad!!
I also see John Bownes sells reconditioned axles. Would these be original Roadless axles or 'new' GMC axles they have converted??
redgiant
Re: Can You Still Get The GMC Axle They Used On Roadless Tra
Postby county654 » Fri Aug 05, 2016 6:07 pm
Hallo,
your problem is not the axle, your problem will be the gearbox .
A reconditioned unit should have both.
What would be a good Price for a Roadless Major?
Two or three times a year I seee an offer here in Germany and the surounding countries.
Regards Matthias
With County, you can ;-)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
county654
Postby redgiant » Fri Aug 05, 2016 10:26 pm
Well almost none come up for sale in Ireland, so realistically I have to look to the UK. I think I'm right in saying that a Roadless Major could go for anything from £3000 upwards for a poor example. Add to that commission, VAT, transport and converting to Euros and it can work out quite a lot :shock:
The picture I saw of the reconditioned unit was of the axle only, though you make a good point. I would imagine it would be very expensive.
As for the transfer box......I'll pass that hurdle when I get to it. IF I ever get to it!! :D
redgiant
Who is online
