Assistor rams for 1963 County Super Six
Hi folks, I'm wondering if any one can help in my search for assistor rams to fit a 1963 Super Six (based on Super Major, not thousand series). I realise my simplist option may be to have new ones made but I cannot get hold of original drawings/dimensions either to achieve this. I have built a full replica heavy duty linkage on my County as I require it for use with a subsoiler, I've also made all brackets for the rams and bought the valve coupling to connect them, but my search for a ram or even enough information to have them remade has drawn a blank. Can any one help??
Re: Assistor rams for 1963 County Super Six
Well to update everyone I found a tractor fitted with original assistor rams which the owner kindly allowed me to measure. I took these measurments to my local hydraulic and engineering specialist and had a new pair made to the original design and size which thankfully fitted into my brackets superb and i now have fully operational heavy duty linkage with twin assistor rams...... just goes to show, with enough thought and determination anything is possible!
Concrat with the parts.
Maybe a few pictures??????
I'd like to see some pictures, too. I'm sure that the ones on my Super 6 aren't original.
Well finally the least techno minded person on here managed to upload some photos of my Heavy Duty lift linkage I have built up on my Super Six. All based on original lift linkage but modified according to measurements taken from an original kit I was kindly allowed to measure. It is as accurate as you can get including the rams which I had to have made having exhausted the UK in my search for any! A Labour of love
Thanks for sharing. Very neet job.
My plan is to use this setup for a system to block my lift from dropping when an implement as my plough is in the lift.
Keeps the street and my plough in good shape.
