Wheel weights
Martijn
Wheel weights
Post by Martijn »
Hello everybody!
I'm looking for a set of wheelweights for a Fordson Major.
I prefer a complete set (6 pcs) but only the 4 outside weights will do also.
I hope somebody in Holland will react as sending them over from the UK will be a bit expensive..
Thanks.
Martijn
Pascal
Post by Pascal »
Hi Martijn,
I think every Major-owner is looking for those. :D Including me. 8)
Unfortunately there are really rare... :cry:
Best regards,
Pascal
Martijn
Post by Martijn »
Hi Pascal,
So the fastest en maybe also the cheapest way to get them, is to let a factory make a copie of an original one and cast a complete set for me... It costst around 2 euro/kg.
If you find any over here then the Fordsontractorpages land train will be coming to Meddo in September. That could considerably reduce costs :D
(Donations to the Guldner Purchase Fund might be acceptable) :D :D :D
Frans
Post by Frans »
well thats 3 of us but only original ones
regards Frans
who's afraid off blue orange and grey
1960 Power Major Roadless 6 cyl conversion
1964 NP Super Major
Gman
Post by Gman »
Pascal wrote:Hi Martijn,
Hi Pascal, are the weights like the ones on the back wheels of my power major? Just wanting to know if I have something rare on mine. I'm told the double clutch she has is also not that common. Good luck to all.
Gerald
Gman: 1959 Power Major
Martijn
Post by Martijn »
Thank you Brian,
I'll keep that in mind..
When you come to Meddo, you should visit me and have a look at our interesting Ford/Fordson collection..
We even have a Fordson Major Diesel with blue grills. :wink:
Martijn
Roadless63
Post by Roadless63 »
Ive just sold all my spare weights, prices over here seem a bit up and down. I had some very late super major ones with the fomoco script which fetched over £50each. It seems a set of 6 (enfo/e27n script) are fetching £250+ and that doesnt usually include bolts or cast washers.
If I come accross any more I'll let you know.
Ed
EddieJ
Post by EddieJ »
Is this what you guys are after?
http://cgi.ebay.co.uk/Ford-Fordson-rear ... 27af65a781
What do these fit? May Brian can help on this one:
http://cgi.ebay.co.uk/Ford-Tractor-Whee ... 27af6668ce
8000/9000 or even TW.
Pascal
Post by Pascal »
Hi Gman,
Yes the wheel wheights look like the ones on you tractor. Do you have any close ups? Especially from the bolts inside the rear wheel?
There seems to be ones with Fomoco (Ford Motor Company?) and one with EnFo (English Ford?) inscripted.
I don´t know which ones I should have for my '61 Super?
Hi Martijn,
Looking forward to see your Ford-Fordson collection! :D Any pictures by chance? Where you at Meddo last year?
Best regards,
Pascal
Roadless63
There seem to have been several scripts used on the E27N and E1A major wheel weights, I had nearly 50 piled up around the place and there seemed to be 4 types. large curved "ENFO", a plain E27N, a smaller "ENFO" and finally FOMOCO. Apart from the script they looked the same. Of course the inner or starter weight (quite rounded on the inside to match the dish of the wheel) has 5 holes around the perimeter and 3 inside to which the outer "flatter" weights are bolted.
Will post pics when get time. Later 1000'nd series weights have all got 6 holes and are not interchangable with major ones (unless you fit later wheels)
Regards.
Martijn
Post by Martijn »
Ha Pascal,
No, I wasn't at the Meddo show last year. I've never been there.
We always go to the HMT Panningen show with five ford/fordson tractors. Mostly with a fordson F, two fordson N's, a E27N and a big Ford 9000. Look at: http://www.youtube.com/watch?v=NvJRUwOr4EU and watch me leaving the showsite...
greetings,
Martijn
Martijn,
Has it anything to do with these tractors?
Martijn
Post by Martijn »
Henk,
No, these are from our friends, who also have a lineup of fordson tractors.
Look at the youtube site and maybe you will recognize them from the show..
Martijn
Pascal
Post by Pascal »
Wow, Martijn, that's quite a combination you drove! :D
Impressive.
Which shows are you planning to visit this year? Panningen again?
Best regards,
Pascal
Martijn
Post by Martijn »
Pascal,
Panningen is the only event we go to..
Last year was the 18th time we went there with some of our tractors.
Just haven't got time enough to go to many places with materials..
Martijn
MAXPOWER
Post by MAXPOWER »
i didn't know the wheel weights were a rare item i have the full 6 plates on the rear and even front wheel weights
Pascal
Post by Pascal »
Hi Martijn,
Looking forward to see your tractors this summer @ Panningen.
I hoep to go there by tractor myself. Maybe after the 6 cylinder conversion? :) It's quite a drive from Amsterdam to Panningen. :D
Hi Maxpower,
Lucky you! :D
Could post some detailpictures of your rear wheel weights? Especially from the bolts inside the wheel? They seem to have a special shape, I have heard.
Best regards,
Pascal
MAXPOWER
Post by MAXPOWER »
Pascal i do not have pictures but the bolts were held in rectangular blocks which locked the bolts and kept them from turning.
Tiger
Post by Tiger »
Another unfinished project
