brake lining removal
Postby terry274 » Mon Sep 08, 2008 2:33 am
I have new brake linings ordered. The lining on the shoes are bonded on, the new ones will come with rivets. (I am only getting the linings, not the complete shoe) What is the best way to remove the old, bonded, linings?
Thanks,
Terry
terry274
Postby aldo » Mon Sep 08, 2008 8:43 am
Hi Terry. Just guessing, but I would say what ever it takes -maybe hammer and chisel, then clean up with a grinder or sand paper. Don't forget, your probably dealing with asbestos - I would keep it wet to avoid dust.
PS. You got me wondering, Terry, so I did a google search. Didn't find much except this:
"I removed the old lining from my disc and sent them to the brake company. If your old pads were bonded don’t bother trying to remove the pads. The company can heat them in the oven and they will slide right off."
aldo
Postby terry274 » Mon Sep 08, 2008 11:50 am
Yeah, a hammer and chisel is what I was thinking. Thanks for the idea about keeping them wet, I was concerned about the asbestos. I found nothing at all on the internet about removing the linings. Since brakes and clutches get hot during normal use, I wonder how hot that company heats them to get the old lining off?
Thanks,
Terry
1964 Fordson Super Dexta
terry274
Postby aldo » Tue Sep 09, 2008 11:10 am
terry274 wrote:Since brakes and clutches get hot during normal use, I wonder how hot that company heats them to get the old lining off?
Thanks,
Terry
I also read that the bonded drum brake linings are baked on, they place the glue and clamp the linings on, and bake it. So the 'glue' must be able to take high temps. I've never seen a clutch cemented on, always rivets.
aldo
Postby llanfair » Tue Sep 09, 2008 7:41 pm
Hi terry,
As your brake shoes have bonded linings and you intend replacing with riveted linings are the shoes drilled to suit, (only a thought)
Regards LLANFAIR.
llanfair
Postby terry274 » Tue Sep 09, 2008 7:50 pm
llanfair, yes, the shoes are already drilled.
terry274
Return to Fordson Dexta
Who is online
Users browsing this forum: No registered users and 4 guests
cron
