Hello All
Stew1174
Hello All
Post by Stew1174 »
Hello, My names Stewart and own a County 1174 thats in need of a bit of TLC.
Kiwi Kev
Re: Hello All
Post by Kiwi Kev »
Stew1174
Welcome to the forum.
What sort of TLC does the 1174 need?
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
frode
Re: Hello All
Post by frode »
Welcome, and please post some pictures of the 1174 :)
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
Stew1174
Re: Hello All
Post by Stew1174 »
It needs some cosmetic work, some body work (mostly on the cab), the injector pump isnt to good and the wiring is shot. Other than that she's fairly tidy.
I belive she was imported back from Japan and sold to the dealer/ collector i bourght her off of at the begining of the year.
As i got her.
Befor export from Japan
frode
Re: Hello All
Post by frode »
Nice! Looks like you have some work to do on the cab :)
Mark Osborne will help you out with a new wiring loom.
frode
1964 County Super-4
1967 County 654
Stew1174
Re: Hello All
Post by Stew1174 »
Thanks :D
The rust isnt to bad over most of the cab, the rearly bad bits are the right hand wing and the sunroof where its had an aftermarket air con system fitted. I do need a door and a rear window though.
I hadn't thought about trying Osbournes for a wiring loom, i'll have to give them a call.
frode
Re: Hello All
Post by frode »
You can try Stewart Trailers in Scotland for parts for the Hara-cab. The owner is a genuine county-fan and fabricates parts for the cab in his shop. I think he can supply all the parts you need. I saw Mark had 1174 wiring looms for sale at his stand at the Blue Force Conversions Day in Lincoln a couple of monthis ago :)
frode
1964 County Super-4
1967 County 654
Stew1174
Re: Hello All
Post by Stew1174 »
Thanks Frode, I called Mark at Osbourns the other day and he keeps 1174 looms on the self, It turns out the crispy fried loom problem isnt uncommon :roll: I'm going to take a trip down there to get a few bits when im home next.
Pascal
Re: Hello All
Post by Pascal »
Hi Stew1174,
That's a great County, you have! 8)
Must be quite impressive to drive?!
I hope you will find the parts you need.
Best regards,
Pascal
