Today I have been mostly.......
Re: Today I have been mostly.......
am i the only one who can't see the photos?
Me too Chriss.
Niel, could it be that your pictures are behind a login?
I can see them, both now, and this morning when I looked.
Kiwi Kev
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Looks like you need to be a member of the forum to see the pictures as they are password protected.
logged in but still can't see them
Sorry Chriss, you need to be a member of Neil's forum to see the pictures not this one.
edited, thanks for the heads up,
and Kiwi Kev is a member of the other forum too
Now I really need to clear out 'the stores' so I can get it under cover.
What's an unknown condition, but turns, 590E worth with injector pump and manifolds?
Hineilarmo wrote:edited, thanks for the heads up,
Nice looking tractor on the whole but got some odd parts on and a some missing
So for us that are missing something here whats the other "secret society" forum you guys are members of .
The 590 or 6D as most know it, are better if complete known runners, they had a bad reputation for wearing the cranks the same as Major motors. if you start it and find low or no oil pressure when warm. You got to either hope the crank can be re ground, or find a good one to replace it if worn past 30 thou re grind.
The oil pump is bigger than a standard major motor I believe as well. Don't know of anybody doing new cranks or oil pumps for them . I would be at scrap price plus a bit. good ones seem to be making around 300- 500 quid plus, on Flea bay at the moment, allowing for people that don't know when to quit bidding .
I Got an early one here in Canada and can't find a crank to fix it at the moment. you may have a better chance in the U.K finding good used cranks if needed . see plenty of parts to fit them around for almost everything else. some of it is the same as the major, only more of them used like sleeves, pistons rings. gasket sets are available also from a few guys
They can also suffer from the same block sealing ring problems as the major motor can with corroded seal grooves/rotted liner bottoms, or dried out leaking liner seals, really a dry stored non running motor is a huge gamble full stop when i think about it . you won't know it might be trouble until you own it and try running it if buying one .
sorry it's not really a positive outlook on the motor but junk is out there and these things are getting way past legal smoking age and very close to getting an early retirement pension
I have a top link bracket in the shed so that's sorted.
Tractor had a loader on from new so had the silencer through the bonnet and the smaller bonnet handles so loader didn't catch. Seems to make sense.
Is it the proper new performance top link bracket?
unfortunately not, but I'm looking......scoobyjim wrote:Is it the proper new performance top link bracket?
Nice find. Dandy Dave!
I need one too. May have to look at borrowing one off someone and getting some cast.
Lo and behold a tractor with a ploughing lamp fitted
shhh, I think it's just single bulb.Jimcdbts wrote:Lo and behold a tractor with a ploughing lamp fitted
the one on the other super is just a 1970's afterthought
The photo appears to show a Super hydraulic lid, and not a NP Super lid. To be sure, does the lid have an aluminium knob near the pressure relief valve?
Best
Adrian
Best
Adrian
