roadless/selene axle diagram
d.andersen
Post by d.andersen »
Anybody got a diagram/picture/drawing of a selene / roadless frontaxle on a super major, diff. bearings etc.
also anybody know where to get new gaskets and sealings ??
Fordson forever
Grani
Re: roadless/selene axle diagram
Post by Grani »
d.andersen
Thanks .
got any experience in reversing the drive on the axles ??
Fordson forever
Grani
Post by Grani »
The only way to do it is to simply put the whole axle upside down. That is what they have done on Fordson Majors.
http://www.google.fi/imgres?imgurl=http ... 14&ndsp=20
http://www.google.fi/imgres?imgurl=http ... =0&ndsp=15
d.andersen
Ok but should it not be possible to simply turn the diff. Around ?
On roadless there is a extension axle for the pto ,
Do they also use that on selene , when the 4 wd box is not so
thick ?
Fordson forever
d.andersen
the diff house is already sitting in the right side , but is
made for reverse driving (like on loaders)
Fordson forever
Grani
Post by Grani »
d.andersen wrote:the diff house is already sitting in the right side , but is
The gears do not fit the other way in the housing. If the axle is from a backloader you have to put it upside down to get it right for a normal Major.
d.andersen
Ok but then the drive shaft will turn forward would it not ?
And the bracket for mounting will then turn down will it not ?
On the picture of the truck/lorry you sent , the sits in the right
side that is not possible on tractor .
Fordson forever
Grani
Post by Grani »
With the two pictures you can se the diff at it´s original position on the truck it was designed for, and how it is the other way on the Major. The shaft is allways pointing backwards.
d.andersen
Yes but as i can see , the shaft will then sit on the right
side
Fordson forever
