Trying to help a guy find one for his petrol Dexta
He also gave these serial numbers
Engine FPL 1598E
Hydraulic M5F
Gear M13F
Petrol Dexta wiring diagram?
Owner of a 1961 fordson dexta restyled model
Re: Petrol Dexta wiring diagram?
Tractor ls located germany
Thanks for those numbers if he can find the engine number and serial number as well it would be even better.
The wiring diagram is impossible to find for a petrol as far as I know but it is not all gloom. Everything is the same as a diesel apart from the wire to the solenoid and ignition coil however there are three looms for a petrol Dexta quoted in the parts book, 1960 to1962 and 1962 to 1964 then one for tractors without lights.
