New Dual Clutch
New Dual Clutch
My 58 Dexta engine is being overhauled and I decided to splash out on a new dual clutch (Agriline). When I gave it to the engineer and told him it was "bolt on" he looked a bit suspicious - so my question is, was he right to be. Does anyone have experience of fitting one?
Re: New Dual Clutch
You are right, it is simply a matter of bolting it on. Both plates are already fitted and aligned. I have just fitted mine and I was intending to update my post on the matter with pictures but I haven't got round to sorting out the pictures yet. The tractor reassembled ok and the pedal feels right with 2 distinct stages of force but I have yet to go through the setup procedure in the manual. Also beware of the replacement clutch release bearings, they are too thin, I made up a spacer as did Brian. See
http://www.fordsontractorpages.nl/phpbb ... f=3&t=6256
and
http://www.fordsontractorpages.nl/phpbb ... f=3&t=5793
Ian
and
Ian
Re: New Dual Clutch
Many thanks Ian, he's going to check the depth of the Thrust Bearing.
Re: New Dual Clutch
Not only is the thrust bearing too narrow and needs a spacer but the surface is also too narrow. I had to get a completely different bearing to the one supplied to get the buttons to run in the right place on the thrust surface.
The replacement bearing supplied with the clutch had a longer inner track which would have rubbed on the buttons when the clutch was depressed. You can see from the picture that the original has the inner track set back from the thrust surface. If the inner track protrudes through the bearing it will wear the buttons as it does not turn.
Not a brilliant picture but you can see where the inner track finishes on the original bearing. The replacement you use needs to be like this.
Re: New Dual Clutch
I'm glad I started the post, thanks guys.
Re: New Dual Clutch
Hi does anyone have information on how far the 6 release bolts should be above the arms mine are all over the place clutch plates seem fine though. thanks
Re: New Dual Clutch
you might call them buttons??
Re: New Dual Clutch
Sorry can't help with the correct adjustment details, but does this help describe the "buttons"?
Re: New Dual Clutch
Yes it does, i have found another issue with the leavers so it looks like I need a replacement!!
Re: New Dual Clutch
Anyone else in this situation have a look at May Hill tractor spares the price seem very good.
