Ford 6610 power steering
hi all, I have a ford 6610 2wd with tanco 878 loader, she has always been good at steering but just lately when I get a haulage bale on the front she is hard to steer, does anybody know what the problem is
- Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Re: Ford 6610 power steering
What steering set up do you have? Is it full hydrostatic, or is the steering box under the fuel tank with a drag link to the front axle?
I would likely start with the pump. Check the fluid level in the reservoir and make sure the filter is not collapsed.
Most hard steering issues that I have had on any of our Fords has been a result of a low fluid level.
HTH - SR
HTH - SR
Fordsons: 22 F, 36 N, 50 E27N, 60 FPM Past: 60 Dexta, 61 SM
Fords: 78 6700 Turbo, 81 TW30, 89 4610 4x4 w/ Frey ldr, 96 7740 SLE 4x4 Past: 72 4000 w/ Allied 660 ldr, 75 5200, 76 9600
Others: MH 30 & 44, Oliver Super 55, Bobcat 440b & 773
