Howdy to all Fordson Gurus.
Just got my generator back from the rebiuld shop and was wondering to I have to "flash" it and if so how? They said it was in good shape other then needing a bearing and the brushes were getting short. So got them to put in two bearings and the brushes. Thanks all for your advice.
Generator gone through by rebiuld shop. Do I need to Flash
- Location: Ft McMurray Alberta Canada (work) Cherryville, British C0lumbia Canada (home)
1964 Super Major 5000 with FEL and Backhoe. Unfortunately no PTO or Three Point Hitch
Re: Generator gone through by rebiuld shop. Do I need to Fla
Any shop worth dealing with ought to ensure output is OK by running up on a test rig after replacing bearings and brushes, refit and try it, you can always flash it in situ if needed
Thanks. Good advice.
