Help with identification
Postby georgey48 » Fri Oct 04, 2019 7:22 am
Morning,
Ive recently bought a Dexta that is in need of a bit of work but it seems a bit of a bittsa and im wondering if one of you knowledgeable people can steer me in the right direction. The tin work is an assortment and the wings aren't even Fordson but the Serial number seems to indicate its a Dexta (from guide on Tractor Data) but it has the Super Dexta pump and some of the hydraulics ?
Serial No: 09C732617
Casting No's: Gearbox: 957E 7005 also: P21H ?
Engine: 37111310 there is also a: L272 and at the bottom back: GKN1372 1C
Im afraid ive not been able to locate the clutch, hydraulic top that people talk about, might need further investigation.
Left hand trumpet looks like it has: 957E 4013B
Any help appreciated.
georgey48
Re: Help with identification
Postby charlie63 » Fri Oct 04, 2019 7:18 pm
Georgey48,
Hopefully the following will help you in identifying the year of Dexta you have.
From my information that I have your tractor serial number dates it to Jan 1963.
The gearbox casting code dates from Dec 21st 1962.
You need to get the casting codes from the rear trumpets as in below photos to date them. These are the same as your gearbox casting code which will start with a letter and be either a single or double number followed by a letter. If you can get me them I will date them for you. I am unsure about your engine but you find with many tractors these have been replaced over the years as mine has. My tractor is a very early Dexta but the engine dates to 1965.
Gearbox casting code.
Left Axle trumpet casting code.
Right Axle trumpet casting code.
Charlie
charlie63
Postby georgey48 » Sat Oct 05, 2019 5:19 pm
Thanks Charlie,
Left hand trumpet has: M18H
Right hand trumpet has: M4H
georgey48
Postby charlie63 » Sun Oct 06, 2019 10:49 am
Georgey48,
Your trumpets date from Oct 4th and 18th 1962. Looks like you have a genuine Dexta and not a bitser as all the casting codes date from late 1962 and serial number from Jan 1963. As I said earlier I wouldnt worry about the engine as many were replaced.
Charlie.
charlie63
Postby georgey48 » Wed Oct 09, 2019 8:39 pm
Thanks Charlie, that's a great help.
georgey48
Postby Mervyn Spencer » Wed Oct 09, 2019 8:47 pm
Hi Georgey48,
What is your colour scheme going to be and what year is the engine and also engine number?
Mervyn Spencer
Return to Fordson Dexta
Who is online
Users browsing this forum: No registered users and 3 guests
