Dear readers of the Fordson Forum,
I'm looking for the return pipe assembly of the hydraulic lift system with back pressure valve.
It is for a Fordson Super Major year of make 1963.
I have a part drawing pdf or jpg of it if you wanted a copy let me know.
thanks for looking
MajorFan
Hydraulic Return pipe for lift system Super Major 1963
Re: Hydraulic Return pipe for lift system Super Major 1963
Where are you located on this world? A breaker would be the best option. Otherwise try to copy the tube, then you'll only need the valve itself. i can imagine the valve can be purchased at a CNH dealer.
rgds
rgds
