Topic: E27N differential lock
TK True Blue Posts: 42 From: Norway Registered: Oct 2006
posted October 18, 2007 10:51
Sirs,Removed the top cover from the rear end last night, and my suspections of a diff lock was confirmed. My 51 e27n P6 has a Darlington solid axle drive. Operated by a hand lever on the right hand side of the rear end. It is not a diff lock, but a lock between the two large final drive gears. Is this a common feature on e27n's? Was this a factory option , or a aftermarket option. Thanks Regards TK IP: Logged |
BarryM True Blue Posts: 107 From: Australia Registered: Jan 2005
posted October 18, 2007 13:58
Hi TK,The Darlington Solid Axle Drive is quite rare. I have only seen them in a Sales Brochure. They were an after market item. You are very lucky to have this item. BarryM IP: Logged |
Matt 1944 N True Blue Posts: 8 From: Castle Cary, Somerset, England Registered: Oct 2007
posted October 18, 2007 20:30
Hi, This is very interesting I have only seen a picture of this in the Fordson Major Miscellany - 1 book by Allan Condie, would it be possible for you to post some pictures of it?Thanks Matt IP: Logged |
posted October 18, 2007 23:56
There should be a copy of the leaflet on the board for this dif. lock. Barry from Aus. sent a copy to me and I posted it on here some time ago. Try a search.------------------ Kind regards Brian [This message has been edited by Brian (edited October 18, 2007).] IP: Logged |
posted October 23, 2007 22:41
I am now trying to post a picture of the Darlington axle lock. If that works I will post more pictures later.Regards TK IP: Logged |
posted October 23, 2007 22:52
well I don't see noting but a square with a red x.However, the link to the picture is: http://kleppan.net/img/TK_071023_Darlington-diff-lock-1.jpg TK
[This message has been edited by TK (edited October 24, 2007).] IP: Logged |
posted October 24, 2007 08:13
Hello, Very interesting picture, I wish we had the lock in our E27N.
The picture is somehow protected by the owner. Best regards Emiel IP: Logged |
posted October 24, 2007 10:39
Pictures of Darlington Diff Lock TK
posted October 24, 2007 10:45
Ref previous post.Due to problems with the pictureserver the pictures did not appear in the post. Now everything is OK TK [This message has been edited by TK (edited October 24, 2007).] IP: Logged |
