  Handle Start
Author Topic:   Handle Start
Barry Thomas
posted July 04, 2006 22:00     Click Here to See the Profile for Barry Thomas   Click Here to Email Barry Thomas     Edit/Delete Message   Reply w/Quote
Brian,
Here's one for you, I went on a 196 mile round trip today to pick up a Major radiator (complete with shutters, just what I wanted) after winning the bid on ebay. Met Tim the seller very nice welcoming chap, we saw some of the tractors he was currently working on, in the corner of the tractor shed was an early Diesel Major, looked very original and tidy but for the starting handle which was located on the left hand side of the engine where the starter is usually located?? Tim gave us a demonstration and boy was it hard work turning that handle, or so it seemed!!it sounded just like one of those wartime alert sirens that needed turning with a handle to warn the community of approaching enemy aircraft, then with a quick flip of a lever located on what seemed to be the gearing housing and the Major burst into life and ran as sweet as anything. I have never seen one of those before, was it an original Fordson patent, Tim seemed to think that it was fitted on some export models, I'm just sorry that I did not have my camera with me at the time. I would be grateful of your comments.
Barry
Henk
posted July 04, 2006 22:27     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello Barry,
Seems to me that's a'n inertia starting engine. I have asked about it in a previous topic on 3 Sept 2005, and Emiel explaned how it works.
Regards Henk
Barry Thomas
posted July 04, 2006 22:53     Click Here to See the Profile for Barry Thomas   Click Here to Email Barry Thomas     Edit/Delete Message   Reply w/Quote
Thanks Henk I will have a look at that topic.
Barry
posted July 04, 2006 23:31     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Yes thats the inertia starter. Think it was made by Lucas. it was fitted to a lot of engines even the Rolls Royce Merlin!
Now there was an engine to hand crank to start but thats what they did in desert conditions.
I've seen it used on Nuffield and David Brown tractors.
Barry Thomas
posted July 05, 2006 01:02     Click Here to See the Profile for Barry Thomas   Click Here to Email Barry Thomas     Edit/Delete Message   Reply w/Quote
Brian,
Were they made for the export models, are there many about as I have not seen one before.
Barry
Oscar
posted July 05, 2006 09:06     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
That's very interesting! I never saw one of those either. A picture would be nice .
posted July 05, 2006 10:41     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Barry,
Mostly export and tractors less electrics for special applications.
Mike Kuscher
posted July 06, 2006 00:10     Click Here to See the Profile for Mike Kuscher   Click Here to Email Mike Kuscher     Edit/Delete Message   Reply w/Quote
Hi Guys,
These inertia starters...
Basically a big clockwork spring then, flick the lever which releases the ratchet.
And they try to claim the wind up radio was a new idea!
Interested? There's one for sale, 'brand new old stock' in this months Tractor and Machinery.
Mike
tmac
posted July 06, 2006 00:36     Click Here to See the Profile for tmac   Click Here to Email tmac     Edit/Delete Message   Reply w/Quote
Actually they work a little different than a big spring. They more resemble those little toy cars that you would push on the floor then let go.
These units have a HIGH speed small flywheel that can reach as much as 60,000 RPMs. Basically the crank type 1 either have a bell or an indicator to signal the correct speed, they contain a stack clutch similar to a motor cycle clutch. When cranking is discontinued there is a handle,ring, or lever that is pulled to engage the clutch. The screeching noise you hear is the clutch slipping. The siren like sound is the high speed flywheel turning.
The kinetic energy built up in the high speed fly wheel is what spins the gears over.
These type of starters have been in use since the 1920s on aircraft by all countries. Most of the really big IC aircraft engines are started with these only they are powered by an electric motor, some of which may also be hand cranked if needed. The fighters that had the Rolls Merlin more than likely either had no battery or one so small as to provide only enough output to supply radios and lites. They wanted to put more ammo bombs and bullets in these planes not battery dead weight.
Originally posted by Mike Kuscher:
Hi Guys,
Mike
BarryM
posted July 06, 2006 03:24     Click Here to See the Profile for BarryM   Click Here to Email BarryM     Edit/Delete Message   Reply w/Quote
Hi Guys,
The Inertia Starter used on the New Major Fordson was manufactured by Simms Electrics of London. It was advertised as being suitable for tropical countries where battery life was short as well as for use in refineries and coal mining. Fordsons fitted with this starter generally had no lighting system or battery and generator. (Spark free)
BarryM
ger-man
posted August 06, 2006 12:45     Click Here to See the Profile for ger-man   Click Here to Email ger-man     Edit/Delete Message   Reply w/Quote
Guys,
I found a picture of that Inertia Starter in the club magazine of the "Ford and Fordson Association" issue 12. I hope not getting any CR-problems to make a picture of it to post it here.
To become a member check out their homepage: www.fordandfordson.com
Best Regards
Stefan
www.fordson-dexta.de
