Topic: Tachometer cable
posted January 15, 2005 18:48
I have a tachometer cable with part number: NH-81807563 (957E-17365D)My Fordson parts list says: 957E-17365C Tachometer Cable 11/57-62/4 957E-17365A Tachometer Cable 11/60 957E-17365D Tachometer Cable 4/62
As i can see my cable is used to fit a Dexta with a fuel injection pump with mechanical governing (minimec). My Dexta has a fuel injection pump with pneumatic governing. Do I have to buy annother cable, or can I use this one? [This message has been edited by Johan (edited January 15, 2005).] IP: Logged |
posted January 19, 2005 10:09
Johan,does it fit and is the Tacho running ? regards Jos IP: Logged |
posted January 19, 2005 18:07
Jos, I haven't tried it yet. It's not easy to fit. First I have to dismount the gear shift levers, the Steering box covers, and the instrument box. I would be pleased if i knew it is going to fit, before I start the job. regards Johan IP: Logged |
posted February 12, 2005 22:27
Today i tried to fit the cable... -Unfortunately it is too short. The tachometer cable with part number: NH-81807563 (957E-17365D) is a product with high quality, but does not fit a Dexta with pneumatic governed injection pump. Propably it will fit a Dexta with mechanical governed injection pump. IP: Logged |
ger-man True Blue Posts: 280 From: Germany Registered: May 2003
posted February 12, 2005 22:48
Johan, the pneumatic pump was fitted from 57 up to 62. All the Dexta and Super Dexta built after 62 were fitted with the mechanical pump. So the right cable for your sweety should be 957E-17365-A. IP: Logged |
posted February 13, 2005 11:08
-Are you sure? As i said from the beginning, according to my spare parts manual the right cable would be 957E-17365C for my Dexta (made in february 1962). However... Today these numbers are quite unusable. Do you (or anyone else on this board) know if Ford-NH still have the 36" (915mm) long cable for Dextas with pneumatic governor in stock? In that case i would be pleased to know the spare part number (NH-number). // Johan.
[This message has been edited by Johan (edited February 13, 2005).] IP: Logged |
Mark Burgess unregistered
posted February 13, 2005 17:28
I would be interested in that part number too! I need a 36 inch cable for my dexta. MarkIP: Logged |
posted February 14, 2005 10:09
Guys, I bought a 36" cable from Hartmut Lindner last year. The old number is 957E17365C and that is NewHolland 81718522. Hope that will help. So the number 957E-17365-A that I told you is not correct. Stefan
posted February 14, 2005 12:06
Today the parts dealers are no longer interested to help us with the old machines. We must go to the dealer and bring our own part number. When you go without a number you will get an answer:"No number, no parts!" If their computers went out of work, they must lock their doors. Stefan IP: Logged |
posted February 14, 2005 21:55
Thanks, Stefan... Summary: 36" (915mm) Tachometer cable for Dexta with pneumatic governor: NH-81807563 33" (840mm) Tachometer cable for Dexta with mechanical governor (Minimec): NH-81718522 [This message has been edited by Johan (edited February 15, 2005).] IP: Logged |
posted February 15, 2005 05:46
Thanks Stefan, I will call tomorrow and see if they have one. MarkIP: Logged |
posted February 15, 2005 05:58
Johan, watch out, my Dexta is one of the fast Dexta from 1959 with pneumatic pump. The number NewHolland 81718522 is for a cable fit to my old girl. Not for Super Dexta! StefanIP: Logged |
posted February 15, 2005 18:10
Today I've got a new cable. This one is marked: "NH-81718522". But... -It don't fit, either. This cable is about 55" (1397mm) long, and there is no nut in one of the ends. What have i got? IP: Logged |
Mervyn Spencer True Blue Posts: 153 From: Pietermaritzburg, Kwazulu-Natal, South Africa Registered: Apr 2005
posted November 16, 2005 17:45
Hi FolkI am now needing to buy a tachograph cable for my Super Dexta(mechanical). I have read your comments about the various size and length cables and have to ask why should there be bifferent length cables? I do have a Sparex replacement parts cataloque and the nh part number is the one last meantioned ie.81718522 sparex number is S.75961. I am also needing to buy a tachometer as my S Dexta did not have one, it had a blank plate riveted to the consol. When I buy my tachometer how do I fix it to the consol? Look forward to any help thanks. Regards Mervyn IP: Logged |
Dunggatherer True Blue Posts: 142 From: Breezand,Netherlands Registered: Jun 2004
posted November 20, 2005 20:56
Last year i bought a new tach and it came with two "clamps" whick you can tighten with two also provided nuts. First you put the tach through the hole from the upper side,then you fix it from the inside with those parts mentioned. Pretty simple fix. Good luck.IP: Logged |
posted November 21, 2005 06:49
HiThanks for the above information. You don't mention the ring that the tacho fits into stands about 50mm proud of the consol, do I understand correctly that you have fitted your new tacho directly onto the consol without the ring. Regards Mervyn IP: Logged |
posted November 23, 2005 19:29
No of course you are right. I forgot that part.And i also forgot to mention the fact that my new tach was just a little bit too big.But a few strokes with a file soon cured the problem. Have fun!IP: Logged |
