Hi, I have two grilles and crank handles for my 1949E27N.
My question is - in the photo you will notice the grille which is not on the tractor. What model Forsdon was this grille originally on and what year models?
Would it be wrong to put it on my tractor as it is in much better condition than my smashed up one???
Also the crank handle which is not on the tractor has a spring on it which pushes the handle out from the dog. should I have the spring on the tractor? At this stage it does not have one but that doesn't mean it hasn't been removed previously. I noticed the crank handle which still has the spring has a hole drilled through which I'm assuming a pin went through to retain the spring. My tractor handle doesn't have this hole.
hi as far as i know and one allways learns the crank should have the spring how ever if the dog is a bit worn it can make it jump out the flat grill i belive is pre 48 49 suposedly they changed when the perkins came out to improve cooling which is that time however we are allways a bit behind out here and the petrols probly used them up one of my perkins has the flat grill allso has light axales and rear tank filler hole b
Hi My E27N has the spring on the starting handle it is a pain in the a@@ to use with it though as you have to fight the spring pressure while trying to hold the handle in the start dog .
My dad farmed with E27N's and said I should take the spring off as none of the ones they used had them and it would make the handle easier to use . I'm wondering if the spring is there to make sure the handle does not stay engaged when the motor starts .
The spring is only a problem for me when i don't have a spare battery around as mine has electric start I might just leave it on. I guess the choice is yours on what to do.
Keep the dog area very clean as dirt etc can keep the handle engaged when it fires up and you don't want a bust wrist/arm. Remember to keep your thumb on the same side as your fingers on the handle too so when it does start the handle can pull out of your grip.
You should also have the U clip in place below the radiator grille to retain the handle upright so it dosn't catch in grass etc when running.
Bath
UK
Hi Jerry,
I agree with all you say save the reason for keeping ones thumb on the same side as the fingers. It is not so that that the handle can pull out of your grip when she starts - it would do that anyway if the handle caught in the dog which I have never known happen on an E27N. It is in case it kicks back and if your thumb is round the handle it will break your thumb - very painful and I'm told only happens once as once is enough to learn the lesson. But I bet you never tried to swing your L4 anyway!
A happy New Year to you all
Pat
